midora Posted November 8, 2012 Share Posted November 8, 2012 The following plugins allow the digital image editor "Paint.NET" to render lines and circles combined with some turbulence effect. Useful to create textures like marble, wood slides, flowers, ... Download >> Turbulent.Effect v1.1 (10.11.2012) Installation Unzip "Turbulent.Effect vX.X.zip" and copy the plugins (.dll files) into the "Effects" folder of your Paint.NET installation. A typical location is "C:\Program Files\Paint.NET\Effects". After a restart of Paint.NET you will find the plugins under Menu->Effects->Render. 'Turbulent Lines' Effect Plugin + 'Turbulent Circles' Effect Plugin Options Line/Circle distance: Distance between two lines Line angle: Angle of the line (-180..180) (0 means horizontal) Transition between lines: Defines the wave form used for the pixels between the lines. Depending on the height of the wave the color of the pixel is mapped to the primary or secondary color (or transparency) Available forms are: Half sine wave, Triangle wave, Sine wave, Sawtooth wave and Square wave Invert the transition wave between the lines: Checkbox to select between inverted and not inverted Turbulence amplitude: 0: No turbulance to N: Maximum of chaos Turbulence period: Stretching of the turbulence on the lines Turbulance pattern: Reseed button: Clicking generates a new 3d noise pattern used to render the turbulence Primary color: Color of the lines (Default: Current primary color of Paint.NET) Secondary color: Color of the area between the lines (Default: Current secondary color of Paint.NET) Set transparency instead of secondary color: Checkbox to generate alpha values instead of secondary color .If not selected than the alpha channel is always set to opaque. Go to effect on the web: Clicking the button will open your browser in the location hosting the plugin. Check the location for newer or test versions, help, examples and background information. Examples of rendered lines Examples of rendered circles 1 1 Quote Link to comment Share on other sites More sharing options...
DrewDale Posted November 8, 2012 Share Posted November 8, 2012 Useful plugin, after a quick play around, I found it to be good with text. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 8, 2012 Share Posted November 8, 2012 Nice plugin Martin! The effect reminds me of both Varicose and Dents. Thank you. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Goonfella Posted November 8, 2012 Share Posted November 8, 2012 I like it. Will come in handy for gas planets.Thanks very much. Quote Please feel free to visit my Gallery on PDNFans And my Alternatives to PDN Link to comment Share on other sites More sharing options...
yellowman Posted November 9, 2012 Share Posted November 9, 2012 But, wait a minute, I am confused, are you same midora? Or just happened accidentally? Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to comment Share on other sites More sharing options...
midora Posted November 9, 2012 Author Share Posted November 9, 2012 But, wait a minute, I am confused, are you same midora? Or just happened accidentally? Martin and me are not fighting against each othrt. OK, not always ;-) Quote Link to comment Share on other sites More sharing options...
midora Posted November 10, 2012 Author Share Posted November 10, 2012 Update to v1.1 available: - More transition wave forms between lines - Primary and secondary are now setable inside of the plugins (before you had to set colors in the main application). - Instead of the secondary color the plugin may generate transparent colors. Using the effect on a new layer allows to combine the rendered pixels with other layers. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 11, 2017 Share Posted October 11, 2017 Added link to zipped DLL Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Djisves Posted October 12, 2017 Share Posted October 12, 2017 Thank you for the housekeeping EER. These are two DLLs for two effects in one zip file. Still, I think this topic belongs in the general Plugins forum rather than in the Plugin Packs sub-forum. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 12, 2017 Share Posted October 12, 2017 Agreed. I'll move it. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
