WebP Filetype (2013-04-06)
  • Please log in to reply
25 replies to this topic
#1 null54
null54
  • Members
  • 218 posts
Posted 26 May 2011 - 04:08 AM
This plugin allows Paint.NET to load and save Google's WebP format.
During testing it saved over 200KB vs JPEG at 95% quality.
(EER Edit) To install place all three dlls from the download in the FileTypes folder.
The Visual C++ 2010 SP1 runtime is required to run this plugin (x86 for a 32-bit OS, or x64 for a 64-bit OS).
When the quality slider is 100% lossless compression is used.
File version 1.0.0.6.
I hope it is useful. :D
Attached File  WebPFiletype.zip   267.77K   332 downloads
Posted Image
PSFilterPdn | PdnFF | Paint Shop Pro Filetype | WebP Filetype | EA FSH filetype
#2 pyrochild
pyrochild
    Plugin Author of the Year 2012
  • Administrators
  • 11,273 posts
  • LocationColorado
Posted 26 May 2011 - 04:18 AM
Well if you're just gonna keep releasing what I'm working on I guess I should just not write plugins anymore :P :lol:
[I write plugins and stuff]
#3 Ego Eram Reputo
Ego Eram Reputo
    Master of Competition Ideas and 2012 Proton Award Winner
  • Moderators
  • 5,765 posts
  • LocationNorth Canterbury, New Zealand
Posted 26 May 2011 - 05:41 AM
You're an admin. Suspend null54's account until your plugin is ready. :devlish: :mrgreen:
#4 pyrochild
pyrochild
  • Administrators
  • 11,273 posts
  • LocationColorado
Posted 26 May 2011 - 05:46 AM
rofl, it's not like I put a lot of work into it. I literally just started it today, after I put that Smudge beta out.
BUT NEXT TIME I WILL USE TEH BANHAMM0RZ
#5 javamanxp
javamanxp
  • Newbies
  • 1 posts
Posted 26 May 2011 - 07:00 AM
Hi,
This plugin doesn't work. How to install ?
When i open a .webp, i'm an unspecified error.
Thanks
Javamanxp
#6 null54
null54
  • Members
  • 218 posts
Posted 26 May 2011 - 03:06 PM
Posted Image
#7 Ego Eram Reputo
Ego Eram Reputo
  • Moderators
  • 5,765 posts
Posted 26 May 2011 - 09:21 PM
This should go in the first post. I'll paste it there for you.
#8 null54
null54
  • Members
  • 218 posts
Posted 04 October 2011 - 03:27 AM
Updated to use WebP version 0.1.3.
Posted Image
#9 skrowl
skrowl
  • Newbies
  • 2 posts
Posted 21 November 2011 - 01:57 PM
Experimental code released to create lossless and alpha channel WebP files : http://code.google.c.../downloads/list
Any hope of getting and update to your plugin?
Alternatively, have your code call .exe files rather than building DLLs. That way whenever there's an update we can just drop new .exe files in to the filetype folder (assuming there are no breaking changes to parameters).
Edited by skrowl, 21 November 2011 - 01:59 PM.
#10 null54
null54
  • Members
  • 218 posts
Posted 28 November 2011 - 12:43 AM
I will probably wait for the next stable release of the WebP libraries.
A few other bugs have been fixed, File version updated to 1.0.0.2.
Posted Image
#11 hajj_3
hajj_3
  • Newbies
  • 5 posts
Posted 19 December 2011 - 08:26 PM
Hopefully Rick will include this plugin in Paint.NET as we need .WebP support built-in. Irfanview 4.32 was released today, that has read/write support for WebP built-in now.
Edited by hajj_3, 22 December 2011 - 12:11 PM.
#12 midora
midora
  • Members
  • 361 posts
Posted 25 December 2011 - 07:27 PM
IrfanView supports WebP via a plugin. It makes no sense to add built-in support to any application as long as WebP is experimental and not defined in a standard. Just because Google has some power does not mean that the format is well-defined.
Posted Image
#13 ekerazha
ekerazha
  • Newbies
  • 3 posts
Posted 24 August 2012 - 09:39 PM
WebP v. 0.2.0 has been released. Is this plugin still developed?
#14 Ego Eram Reputo
Ego Eram Reputo
  • Moderators
  • 5,765 posts
Posted 25 August 2012 - 03:58 AM
Author null54 is still very active on the forum - so I guess (hope) so. I'm seriously considering dumping the JPG format for web photos in favor of WebP.
#15 null54
null54
  • Members
  • 218 posts
Posted 25 August 2012 - 04:17 AM
Updated to use WebP version 0.2.0, File version updated to 1.0.0.3.
Posted Image
#16 nojoe
nojoe
  • Newbies
  • 3 posts
Posted 31 August 2012 - 09:18 AM
Using Paint.Net 3.5.10 with your 1.0.0.3 Version.
No Preview available and when saving an unknown error message pops up.
Also cant open the example files from the latest WebP Codec for Windows (v0.17) package wich is
using the libwebp 0.2.0.
Try it with a 320x240 photo, bmp & jpg.
Win7 x64
Edited by nojoe, 31 August 2012 - 09:19 AM.
#17 null54
null54
  • Members
  • 218 posts
Posted 31 August 2012 - 10:56 PM
Win7 x64
Have all three dlls been placed in the FileTypes folder?
Posted Image
#18 RSguideMaker
RSguideMaker
  • Members
  • 33 posts
  • LocationUnited Kingdom
Posted 02 September 2012 - 11:41 PM
Works perfectly. Thanks! :)
Posted Image
Posted Image Posted Image
#19 nojoe
nojoe
  • Newbies
  • 3 posts
Posted 03 September 2012 - 09:48 AM
Yep!
And no security access scanner is running.
Latest Windows Updates (Net.Framwork, etc) are installed.
Uninstalled and reinstalled Paint.Net. No other effects installed.
Only OptiPNG filetype installed.
Edited by nojoe, 03 September 2012 - 10:00 AM.
#20 null54
null54
  • Members
  • 218 posts
Posted 03 September 2012 - 11:24 PM
Yep!
Have you installed the VC2010 SP1 runtime that the plugin requires?
Posted Image
