OpenRaster Filetype
  • Please log in to reply
26 replies to this topic
#1 Zagna
Zagna
  • Members
  • 244 posts
  • LocationRovaniemi, Finland
Posted 06 February 2011 - 12:46 AM
Ok, here goes nothing :Xemote:
So after finding Pinta's OraFormat.cs and pitching it at others here, null54 came to the rescue and fixed everything. And shrike asking to publish it, here's my attempt.
Thanks go to Maia Kozheva and null54. :mtdew:
OpenRaster Plugin (source)
Just run it Agree to license and press Install. It'll find the folder by itself.
So there it is, hope it works and.... something.
Edited by Zagna, 18 February 2011 - 07:34 PM.
Posted Image
#2 arcr
arcr
  • Newbies
  • 5 posts
Posted 06 February 2011 - 04:07 AM
Cant open images created with MyPaint. Says: "Could not find file"
#3 Zagna
Zagna
  • Members
  • 244 posts
Posted 06 February 2011 - 02:41 PM
I can easily open .ora files created with MyPaint and that error sounds like it's file in a strange place rather than the plugin? No idea.
Can you put a PNG or JPG file the same folder and do they open?
Posted Image
#4 arcr
arcr
  • Newbies
  • 5 posts
Posted 06 February 2011 - 10:46 PM
This is what is inside .Ora file:
Posted Image
And this is the message I get when try to open it whit Paint.NET :
Posted Image
"No se pudo encontrar el Archivo" = "Could not find file"
Edited by arcr, 06 February 2011 - 10:47 PM.
#5 arcr
arcr
  • Newbies
  • 5 posts
Posted 06 February 2011 - 10:49 PM
yes, they open.
#6 null54
null54
  • Members
  • 218 posts
Posted 06 February 2011 - 11:03 PM
It seems like it is not able to find a file within the ora file, but the ora looks like it is correct in the screen shots. :/
Could you attach the ora file in a zip?
Posted Image
PSFilterPdn | PdnFF | Paint Shop Pro Filetype | WebP Filetype | EA FSH filetype
#7 arcr
arcr
  • Newbies
  • 5 posts
Posted 06 February 2011 - 11:20 PM
Ora file
#8 null54
null54
  • Members
  • 218 posts
Posted 07 February 2011 - 02:15 AM
That file loads fine for me, I have no idea what the problem could be. :(
Posted Image
#9 arcr
arcr
  • Newbies
  • 5 posts
Posted 10 February 2011 - 09:10 PM
Oh... now i can open it, but in other computer and whit other OS(W7). I think the problem is whit XP or whit the .Net Framework version(3.5) i have in my computer.
#10 Lance McKnight
Lance McKnight
  • Members
  • 1,230 posts
Posted 16 February 2011 - 01:41 AM
Quick question, is this a file type or a plug-in?
Officially retired from this forum. Have a nice day.
#11 Ego Eram Reputo
Ego Eram Reputo
    Master of Competition Ideas and 2012 Proton Award Winner
  • Moderators
  • 5,757 posts
  • LocationNorth Canterbury, New Zealand
Posted 16 February 2011 - 03:28 AM
Both. It's a filetype plugin :D
#12 Lance McKnight
Lance McKnight
  • Members
  • 1,230 posts
Posted 18 February 2011 - 02:55 PM
So it goes into the File Type folder or Effect folder? Sorry for these questions, the OP didn't make it clear where it should go.
#13 Sarkut
Sarkut
  • Competition Hosts
  • 3,206 posts
Posted 18 February 2011 - 02:57 PM
It goes into the File Type folder.
Running the .exe will put the .dll in the File Type folder.
Edited by Sarkut, 18 February 2011 - 03:00 PM.
Posted Image
#14 Lance McKnight
Lance McKnight
  • Members
  • 1,230 posts
Posted 18 February 2011 - 05:05 PM
Thanks, Sarkut.
I think the OP need to amend the post and clear it up.
#15 Ego Eram Reputo
Ego Eram Reputo
  • Moderators
  • 5,757 posts
Posted 19 February 2011 - 02:25 AM
The thread title is "OpenRaster Filetype". Is that not clear enough? :/
#16 Lance McKnight
Lance McKnight
  • Members
  • 1,230 posts
Posted 19 February 2011 - 10:45 PM
Nevermind.
Edited by Lance McKnight, 19 February 2011 - 10:51 PM.
#17 CH5771
CH5771
  • Newbies
  • 5 posts
Posted 24 February 2011 - 11:33 AM
*double post*
Edited by CH5771, 24 February 2011 - 11:35 AM.
#18 CH5771
CH5771
  • Newbies
  • 5 posts
Posted 24 February 2011 - 11:34 AM
Hi,
first: Thank you very very much!!!! I'm working a lot with MyPaint and Paint.Net and you Plugin is exactly what i need.
I can open an .ora file without problems into Paint.Net - this is really perfect.
but....
I can't save any images from Paint.Net to .ora ... everytime i try i just get the screen: "an unknown error appears while saving" (see attached german screen)
I don't know what to do... pleeeease help :)
Some info: Paint.NET v3.5.7 , MyPaint 0.9.0, Windows Vista with all updates.
Edited by CH5771, 24 February 2011 - 11:47 AM.
#19 Zagna
Zagna
  • Members
  • 244 posts
Posted 24 February 2011 - 12:03 PM
I have no idea what the problem is. It used to work fine earlier..... what if it's due to 3.5.7's changes.... no idea at all.
It's happening to me too, PDN 3.5.7 and Win 7 SP1.
Posted Image
#20 CH5771
CH5771
  • Newbies
  • 5 posts
Posted 24 February 2011 - 12:10 PM
I hate it... "This update improves reliability of saving" ... or non-saving ... *hmpf*... so back to the developers discussion to get it fixed :)
Edited by CH5771, 24 February 2011 - 12:12 PM.
