Color Aberation (ymd:100726)
Color Aberation Effect Plugin
model / effect
( original model from http://www.photo-libre.fr )
What's this?
This is a plugin to move separatly the RGB chanel in % or in pixels. It could be a way to create home made 3D picture but the 3DGlasses aren't provided...
Mixed with/over picture it could give some interesting aspect...
Download it!
Plugin coloraberation.dll
Created with CodeLab...
Upgraded to Csharp version (thanks to @ReMake)
The MadJik's All plugins package is available !
http://forums.getpaint.net/index.php?showtopic=7186
How to install
Close Paint.net
Classic version of Paint.net
Unzip and (re)place the DLL in your Effect folder usually: C:/Program Files/Paint.NET/Effects
Microsoft Store version of Paint.net
Unzip and (re)place the DLL in your Effect folder usually: /My Documents/paint.net App Files/Effects/
You have to adapt for your language My Documents
The User interface
This plugin is added to the menu Effects, submenu Color.
Offset Red/Green/Blue:
...you set the displacement per chanel. The amount is in % by default but you could choose to use pixels. In this case the amount is x100 : 1.0 = 100 px.
Border behave:
...Choose what to do at the borders:
Clamp : Keep and repeat the last pixel from the borders.
Warp : If the image leaves the area on a side then it reappears on the opposite side.
Bounce : Repeat the image from the border as a mirror.
Original : Leave the original picture.
Primary/secondary color : Fill with the selected color.
Offset unit:
...you could slect purcentage or pixels as unit for the offset controls.
Link chanels:
...All offsets use the Red values so each chanel uses the same amount...
Effect Mix:
...This is a slider to mix the final image with the orignal image to make the effect more or less subtile.
The Examples:
Model / Result :
Model / Result :
This is a way to confirm that the yellow color is made of red and green...
  • Thanks 1
