Simple Shiney Discs (good for camera lens... or UFO)
  • Please log in to reply
7 replies to this topic
#1 welshblue
welshblue
    King of Paint.NET for 2012
  • Competition Hosts
  • 4,252 posts
Posted 15 March 2010 - 10:35 AM
As the title says ...
I used them in this:
Posted Image
Posted Image Posted Image Posted Image Posted Image
If you've centred your object, running Radial Blur on the default settings will smooth the edges. This is a play around tut' ... as in play around and try different blend modes etc as the results vary.
Some I played around with:
As I say, these are all play arounds ... I remember there's some Condition Hue/ Saturation in the coloured one.
The shiney one, I made the circles ... duplicated the layer ... set blend mode to Negation ... then used Darken from the Adjustments menu on the layer below to get the bright silverish look.
Enjoy ... and remember to think outside of the box :wink:
Posted Image
Gallery
4 April
#2 pyrochild
pyrochild
    Plugin Author of the Year 2012
  • Administrators
  • 11,249 posts
  • LocationColorado
Posted 16 March 2010 - 01:40 AM
I've edited your title a bit... Maybe consider putting the full images for the steps so people don't have to open several tabs or go back and forth? Also you might want to add some steps on how to make the "shiny button you're happy with." This is the Newbie Playground, after all :D
Posted Image
[I write plugins and stuff] [Follow my stupid brain on Twitter]
#3 welshblue
welshblue
  • Competition Hosts
  • 4,252 posts
Posted 17 March 2010 - 09:24 PM
Thanks Pyro ... will sort it over the coming weekend if that's ok ?
will also add the links to the plug-ins.
Good idea about the UFO. Such a good idea, I'll have to make one
Posted Image
Gallery
4 April
#4 sokagirl
sokagirl
  • Members
  • 1,679 posts
Posted 19 March 2010 - 01:27 PM
This is a great tutorial :D although my outcome is very different ..
Posted Image
Posted Image
Thanks to Chrisco for this wonderful gift signature
#5 Chicholina
Chicholina
  • Newbies
  • 2 posts
Posted 29 March 2010 - 02:48 PM
How to make shiney button in first step? I can not make it concave. I get just a circle. =)
#6 Ego Eram Reputo
Ego Eram Reputo
    Master of Competition Ideas and 2012 Proton Award Winner
  • Moderators
  • 5,646 posts
  • LocationNorth Canterbury, New Zealand
Posted 30 March 2010 - 02:02 AM
Try using the plugin Shape3D over a canvas filled with uniform grey. You will need the sphere tab selected. Flatten the shape with "Depth Radius" in the "Sphere Size" part of the dialog.
#7 Yusuf Zah
Yusuf Zah
  • Members
  • 27 posts
  • LocationSomewhere in a country in the Earth which belongs to the Solar System in the Milky Way.
Posted 05 October 2012 - 02:34 PM
Welshblue, you have a great idea but I must say that you should provide the steps (with pictures) to make the discs.
By the way, you could also start on a UFO tutorial; I don't think there is a single tutorial here yet on how to make a UFO or spaceship. Go ahead and add the steps to this tutorial. C'mon, don't you want me to give you a good rating?
#8 AGJM
AGJM
    2012 Pauly Shore Award (Winner?)
  • Competition Hosts
  • 453 posts
  • LocationSouth Carolina
Posted 12 January 2013 - 02:42 AM
It could also be used to make speakers.  Drop the bass and such.  I might use it later on.
The hardest part of ending is starting again.
