Color Balance+ (works like Photoshop)
dpy
changed the name of the plug in into "Color Balance+" from "Color Balance".
corrected a mistake of the spelling.
Hi!
My 3rd plugin (in this forum)
I created the plugin that works like Photoshop's "Color Balance".
Menu setting
Adjustments -> Color Balance+
The adjustment range is (-100) - 0 - (+100)
"highlight" and "shadows"
In both mode , this plugin works like Photoshop.
Maybe, it is really the same as the result of Photoshop's adjustment.
"Midtones"
In this mode , the result of this plugin's adjustment is a little bit different from Photoshop.
I was not able to build an equation to completely accord with Photoshop's "Color Balance".
However, it's OK , because this is logically correct, too.
Download
This is made by "Code Lab".
Thank you , BoltBait.
japanese page in my site
http://paintnet.web.fc2.com/plugin/dpy/dpyeffect.htm
Edited by dpy
Is this the new version of BoltBait's Color Balance? They both are named the same and I am a bit confused. Would you mind clarifying?
I will download it in a heartbeat, just need some clarification.
Officially retired from this forum. Have a nice day.
Awesome. Loving the ability to choose to modify Highlights, Midtones and Shadows. Thanks! :D
thank you :D
no , this is another plug in . but , the purpose of the adjustment is the same , and so , same name・・・・・
How about "ColorBalanceShop"? :D
or seriously "Tone Balance"?
could some one explain difference between color mixer and this plugin please.
They serve quite different purpose. Color balance shifts global balance of hues while Color mixer can apply different adjustments (saturation, hue shift, brightness, contrast) selectively based on original hue.
With this around, why would you need mine? This is way better.
Maybe it's time for mine to retire.
Nah, i think both of these can be used depending on what you wish to do. Your Color Balance gives a stronger result than dpy's. dpy's can be used for finer adjustments if needed.
_________
Not to be picky, but dpy, you spelt "Highlights" wrong. you wrote "highlits". :P
Merry Christmas
....what about name it Color Balance+, I think we need both, BoltBait's and this.
I agree, let's keep both available.
What is going to confuse users is using the same name for both, so can we please have a point of difference? I like Yellowman's suggested Color Balance+ :!:
Just downloaded.
Excellent plug in but I agree that Colour Balance+ would be a better name. Both are side by side in the adjustments menu and it`s easy to pick the wrong one. :wink:
And my Alternatives to PDN
I played with this plugin last night, and I like it a lot.
May I make a suggestion? Could you make a single thread with all of your plugins and links to your individual plugins? Much like Pyrochild's or BoltBait's index of plugins, and it seems to be very helpful.
No problem at all, dpy. Boude, I was thinking of something like Simon Brown's collection of plugins actually. The index is awesome, but if you know who made what, then it's quicker to go straight to the horse's mouth.
love the plugin man works great!
"Clearly it's a very serious and literal meaning. If you're not solving physics equations then get off my lawn!-Rick Brewster Paint.net Lead Developer"
