Ego Eram Reputo Posted May 17, 2009 Share Posted May 17, 2009 When developing the techniques to create Stereograms (stereogram tutorial), I came up with a number of plugin tools to make the work easier. I'm wondering if these should be released to the general forum? ShiftIt.dll The first tool I developed. It simply moves a layer/selection by a number of pixels. Directions are Left/Right and Up/Down. This tool was useful at first (especially when I needed to repeat the shift multiple times and could do so with Ctrl+F 😉 ), but became largely obsolete after I developed the next two. PDN has to have some way of doing this that I missed right? Echo.dll Tiles from the top left corner in selectable width/height strips. Made to ease the creation of stereogram backgrounds. In the end I was doing this so often I made a Scriptlab script to hack out backgrounds in the twinkling on an eye! Running this plugin replaces steps 3-9 in the tutorial. Although I didn't use the vertical tiling when creating backgrounds, it seemed appropriate to include this facility in the plugin. [edit] run it on an entire layer, not a selection [/edit].  Backfill.dll The heart of the stereogram technique is the backfilling. This plugin takes the cutout element and makes both the initial right shift (step 17) and also does the backfilling (steps 18-26) in one go.   You'll find these three plugins in the (temporary) folder Effects>>Stereogram for evaluation purposes. I'm almost certain to release "Backfill", and tempted to release "Echo". Does "ShiftIt" merit release? Your opinions are welcomed. Stereogram Tools.zip 1 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted May 19, 2009 Author Share Posted May 19, 2009 Oma has pointed out that the Panelling plugin parallels what I did with ShiftIt. I shall discard ShiftIt in favour of the superior Panelling plugin. I would still value opinions on the other two tools. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 7, 2010 Author Share Posted October 7, 2010 Modified build of S-Tools posted. Echo now has larger maximum (also droped ShiftIt as per above post.) Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Eli Posted April 30, 2018 Share Posted April 30, 2018 Hello Mr EER, after 25 years or so, I have finally been able to see a hidden image inside a stereogram . So I decided to create one. Thanks for these tools. I am trying to create one of my own. This is my first try. The hidden ofject is the name of a country. I hope you can see it.  1 2 Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted April 30, 2018 Author Share Posted April 30, 2018 Spain! Great job.  It took me a moment to find it - usually I look for the elements to be side by side. You certainly saved yourself some work doing it vertically  Is it just me, or is there a little vertical artifact in the center?  I usually recommend using a 'less busy' background. It makes the elements stand out much better.  Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
barbieq25 Posted May 1, 2018 Share Posted May 1, 2018 I can see the artifact in the middle but not the letters I do like the colours & shapes though! 1 Quote Knowledge is no burden to carry. Â April Jones, 2012 Â Gallery My DA Gallery Link to comment Share on other sites More sharing options...
Eli Posted May 1, 2018 Share Posted May 1, 2018 Hi! EER and barieq25, The only thing I added is the word SPAIN from top to bottom.  SSSSS PPPPP AAAAA I I I I I NNNN  I can not see any artifact in the middle. Maybe I did too much texturing.  This one is easier to see. I used some shapes and moved them around. Spoiler  1 1 Quote Link to comment Share on other sites More sharing options...
barbieq25 Posted May 1, 2018 Share Posted May 1, 2018 Ah I see the SPAIN now  I see a bit of a blip thing in the very centre of the ASpain one.  Oooh the second one is so nice. Love those shapes & colours! 1 Quote Knowledge is no burden to carry.  April Jones, 2012  Gallery My DA Gallery Link to comment Share on other sites More sharing options...
Seerose Posted May 1, 2018 Share Posted May 1, 2018 Dear @Eli!  That's just so awesome!   I could read very carefully. Thank you for sharing.     Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi  Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted May 1, 2018 Author Share Posted May 1, 2018 Nicely done Eli. The doubled rows of stars are a challenge! Once you realize what to look for they become easier to see. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Eli Posted May 1, 2018 Share Posted May 1, 2018 Thanks @barbieq25, @Seerose, @Ego Eram Reputo. I would like to place a larger shape in the middle but I do not know how to proceed. Spoiler  1 Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted May 2, 2018 Author Share Posted May 2, 2018 Treat any already moved elements as part of the background (merge them - you need a single layer BG). Start your new object using the merged background - just like you were starting over. Â BTW objects placed last/later should have a greater right-shift to make them appear closer to the viewer. The exception to his is when you're using the strip method to backshift an object wider than your phase. In this case give the strip the same right-shift. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Seerose Posted May 2, 2018 Share Posted May 2, 2018  Dear @Eli! Can you maybe write a tutorial? Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi  Link to comment Share on other sites More sharing options...
Eli Posted May 2, 2018 Share Posted May 2, 2018 3 hours ago, Seerose said: Can you maybe write a tutorial? That is funny Seerose. I am still trying to understand EER's Last comment. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted May 2, 2018 Author Share Posted May 2, 2018 1 hour ago, Eli said: I am still trying to understand EER's Last comment.  Have you read through the tutorial thread? There is a lot of explanation there  Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Eli Posted May 3, 2018 Share Posted May 3, 2018 7 hours ago, Ego Eram Reputo said: Have you read through the tutorial thread? There is a lot of explanation there Thanks EER. I will give it a try. If I understood I have to chop the larger image into smaller ones (ABC) and treat each piece as a letter. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted May 3, 2018 Author Share Posted May 3, 2018 That's right. Make sure the strips are less than the Phase (the period of the repeating background). Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Seerose Posted May 4, 2018 Share Posted May 4, 2018 Dear @Eli!  I don't see the layer on your image. Because the other layer I can't see how you handled it. It's possible you're doing this new? Thank you so much.   Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi  Link to comment Share on other sites More sharing options...
