This is basically a small program to diagnose the reason effects and filetypes may not be working. Hopefully this should be easier than looking through the folders manually.
It can currently detect the following problems:
- Subfolders in effects/filetypes folder.
- Zip-files in effects/filetypes folder.
- PDN assembly in effects/filetypes folder.
- Corrupt plugins.
I should probably and may add the ability to fix problems but I haven't for the following reasons:
- Doing so would require elevation in Vista yet it doesn't need that to just detect problems.
- Unzipping files would require extra libraries.
Copyright © Simon Brown 2009
Use at your own risk.
