Chart White Balance and exposure adjustment
yvdh
Hallo,
this plugin can be used to adjust the white balance of a picture based on the white and black patch a standard color chart in the scene. It will use their known sRGB values to bring the image closer to sRGB specs, but it is NOT a full color calibration as described on my website at C4Real. Useful in medical photography, forensics, etc. ...
version 1.0
Supported charts: MacBeth Color Checker Chart A4 and small, QP Card 201.
Instructions:
- Install plugin
- Set primary color to that of the white patch, and secondary to the black patch (can be omitted)
- Adjustments -> Color -> ChartWhiteBalance
- Select other chart if required,turn off use of black if required.
- Close
Any constructive comments are warmly welcomed
Yves
Version 1.1 (12 sept 2010)
Changes
- Not using codelab anymore, full project in VS gives me more flexibility, especially when debugging. Btw CodeLab is still a great tool to get started!
- Added another type of chart we are using (medicol).
- Added some checks which would lead to division by zero errors
- Added a little info on the tool dialog (users were confused without help).
- Appears in the Effects / Photo menu now.
Version 1.2 (13 sept 2010)
Changes
- Added a virtual absolute white and black chart: choosing this means image black is mapped to (0,0,0) and white to (255,255,255). This is useful
for general white balancing
- Added automatic detection of image white and black using a 5 x 5 window
Version 1.2.1 (21 sept. 2010): Bugfix
Changes
- Removed a bug whereby the LUT had erronuous values for R*G*B* index = 1. This was visible as usually brightly coloured single pixels in the image.
Paint.NET.ChartWhiteBalance.zip
ChartWhiteBalance1.2.zip
ChartWhiteBalance1.1.zip
ChartWhiteBalance1.2.1.zip
Edited by yvdh
So the bottom row is the calibration by your plugin, and the middle row is calibration by some other program?
Looks interesting. I have no immediate need for this, but will still definitely play around with it. Do you have to buy that color chart or can one simply print it out?
ambigram signature by Kemaru
[i write plugins and stuff]
Both rows are results of calibration with software I have written during and after my Phd. Unfortunately, the more advanced and better version is not entirely mine to give away.
The chart can be bought online and in specialized stores. The QP chart is about 16 Euros for 2, the MacBeth Color Checker chart is much more expensive at 40-50 Euros for the small and maybe 60-70 Euros for the A4 sized one. This is a much better chart though ...
Yves
  • 3 weeks later...
Hallo,
as far is I can tell Ed's filter is a manual adjustment of the color components scaling (correct me if wrong). My filter is a 3 step lookup-table allowing different scaling for each region (I am working on a 7 step LUT). Also I am using charts with KNOWN colorimetric properties, so althoug the marking of the chart is manual, the actual white balance is NOT. It is fixed to obtain a rendition of the scene as if under a D65 light source and using the sRGB color space.
Yves
  • 1 year later...
Hallo,
just updating the version of my plugin slightly:
Changes
- Added another type of chart we are using.
Instructions:
- Install plugin
- Effects -> Photo -> ChartWhiteBalance
- Close
I am working on a version which will allow interactive marking of the black and white patch. This will allow usage of ALL the gray patches located inbetween. This should result in a much better LUT for the image correction (I have this working already in ImageJ, which is an open source imaging program for microscopy).
Any questions and constructive comments are warmly welcomed.
Yves
Please update the link in the first post so users can find the latest release more easily boltbait.wink.png
  • 6 years later...
This could help in cases where someone wants to cut something out of a plain background...  Sort of like a green screen filter.  Heck, maybe there is a plugin for that?  Only with partial transparency so it is like the white balance where it's not all or nothing like a floodfill, it can add an influence and not just dominate.
Edited by circlularthinking
