Newbie Question Re: Plugins
captainruss
I have used Paint.NET extensively in  making instrument graphics for flight simulators. I am brand new to the forum though.
I need to place objects by coordinates in the Lua code I write to create these instruments.  I need the left. top. width. height valuse to include in functions.  Now I copy these values when a rect is selected with the selection tool.
The are at the bottom of the window where it says   "selection Top Left:  <left>  <top>  and Bounding rectangle size; <width> X <height>
Ironically the text says Top Left but the values are reversed but are exactly  in the order I need, (see attached pic)
I end up writing these values in a piece of paper and later typing then into my scripts.
WOULD IT BE POSSIBLE... either via Plug-In that might already exist, a feature I don't know about, or with the addition of a feature
TO  have some button or contextual menu to copy these four coordinates , comma delimited, into the clipboard.
I right click and select a rect area and a contextual menu pops up with "copy coords".
Selecting would copy the  string " left , top, width, height "  (without the quotes of course) into the clipboard so I could paste them.
Anyone know if this exists, is possible, or how to get such a feature added to paint,NET?  ANyone want to write such a simple plugin if that is possible?
Any help greatly appreciated.
ps. see our work at  www.siminnovations.com
Not possible by plugins; they can only do effects, adjustments, and filetypes. Not context menus.
EDIT: By not possible, I meant the context menus. Good on you, toe, for jumping in so fast!
Here's a plugin.
Effects -> Tools -> Copy Selection Coords
<snip>
Outputs to Clipboard:
left, top, width, height
Edited by toe_head2001
Removed download for outdated plugin
  • Upvote 5
My Gallery  |  My Plugin Pack
Layman's Guide to CodeLab
Here's the source code for those interested. Just a few lines of code (excluding the usually boilerplate stuff).
https://github.com/toehead2001/pdn-copy-selection-coords
EDIT: Here's the code for CodeLab:
void PreRender(Surface dst, Surface src)
    string selectionCoords = selection.Left + ", " + selection.Top + ", " + selection.Width + ", " + selection.Height;
    Services.GetService<IClipboardService>().SetText(selectionCoords);
    dst.CopySurface(src, rect.Location, rect);
Posted code for CodeLab
Here's the source code ...
I'm not sure it is a good idea to have an empty Render function. You should probably be writing to the DST surface for every pixel. Something like this:
    // Call the copy function
    dst.CopySurface(src,rect.Location,rect);
I'm not sure it is a good idea to have an empty Render function. You should probably be writing to the DST surface for every pixel...
Oh, you're probably right. I've heard that mentioned many times here on the forum.
I'd be interested the technical reason for this. What sort of issues could arise from not writing to any of the pixels? Rick seems to have made it somewhat idiot proof, as the original canvas is preserved even though the dst is full of null colors.
Just a curiosity, I'll still fix the code.
Thank you so much for the plugin and your effort Toe_head!  :cake:  :mtdew:
Gandhi
