Sign in to follow this
Followers 0
ScrapbookWithPDN
Lydia's Shapes -Updated 2/20/16 - SUGAR SKULL y Dia de los Muertos
86 posts in this topic
NEW: 2/20/16
Here is a big kit. It's Sugar Skull (Calavera), which is part of Dia de los Muertos; a festival celebrating and honoring those who have died because the dead would not want their loved ones sad since those who have passed away are with loved ones.The zip file is below the sample image. There are many traditional shapes and many shapes made to decorate your skull. Lynxter's gemstone pack could also be used for decorating skulls, as diamonds are often seen on the top center for decorations, as well....but, of course, you can decorate it with whatever you want. The "papel picado" (banner flags) were made with shapes that already come with Paint.Net 4.0 and higher, as was the heart. The skeleton can be put together to show different poses (standing, dancing, playing guitar, maracas, trumpet, etc). You use the same arms and legs but make a copy and "flip" them for the other side. Enjoy this kit.  It's yours.
sugarskull_kit.zip
post-143043-0-15018800-1449347914_thumb.
post-143043-0-24371000-1448948076_thumb.
post-143043-0-76994600-1448947634_thumb.
post-143043-0-72117100-1448735020_thumb.
post-143043-0-39444600-1447911329_thumb.
post-143043-0-85925600-1447911375_thumb.
post-143043-0-80579400-1447911427_thumb.
post-143043-0-10696200-1448092075_thumb.
post-143043-0-78406300-1448430746_thumb.
post-143043-0-06394700-1447619486_thumb.
post-143043-0-71871900-1448387282_thumb.
post-143043-0-59318400-1448486059_thumb.
post-143043-0-16276400-1448587124_thumb.
OK, I'm a PDN user considered NOT even remotely aware of all PDN can do, but I'm doing my best to change that. So, for a 'fledgling' user to give a crack at using the ShapeMaker plugin, here is what I made. I was going to delete them after practicing the use of ShapeMaker but JUST IN CASE anyone out there might like them or might want to use the 3 piece Snowman Shape Pack, here you are:
Special thank you to those at this forum, as someone is ALWAYS around to offer help, and many have. Impressive.
post-143043-0-21911200-1447544024_thumb.
3 pc snowman xaml pack.zip
Edited by ScrapbookWithPDN
5
Share this post
Link to post
Well done, Lydia (Scrapbook)! Great for a practice run. I love your preview pic; you obviously put a lot of effort into it.
Have an early Christmas cookie... :mrviolet: !
I look forward to more shapes.
Thank you for sharing!
Share this post
Link to post
Really nice Shapes Lydia!
The Snowman is lovely. Really well formed. The only suggestion I have is to change the name.....
You can do this by editing the XAML in a text editor. Change the DisplayName where currently it says "SecondSM1".
<ps:SimpleGeometryShape xmlns="clr-namespace:PaintDotNet.UI.Media;assembly=PaintDotNet.Framework"
		xmlns:ps="clr-namespace:PaintDotNet.Shapes;assembly=PaintDotNet.Framework"
		DisplayName="SecondSM1">
	<GeometryGroup FillRule="EvenOdd">
		<PathGeometry>
Alternatively you can reload the Shape into ShapeMaker and type in a name in the Shape Name text box.
Scarf is not properly filled when using the filled Shape option. This is not too much of a problem, but it does indicate that the Shape is in need of a minor tweak.
Both the Scarf and Hat are showing a bad format when ShapeMaker attempts to open them.
0
Share this post
Link to post
That is the cutest cookie! You're so sweet...and creative. Thank you.
0
Share this post
Link to post
		<PathGeometry>
Thank you for the kind words. I figured someone would get around to helping me with it after they actually saw the two tiny issues, and that's very appreciated.
I will remove it until I can figure out what you just explained to me, which I think I can handle it.
I see the issues you see but when not actually used for a shape while using PDN they looked normal when in ShapeMaker, that's why I was confused as to why it happened upon dragging the image onto the canvas via the Shapes tool.
Once I tweak those mystery lines, I'll simply put it back up. Thank you for the help.
0
Share this post
Link to post
Awww - that snowman is adorable - well done ;) .  Glad you managed to upload your file in the end.
The images can look OK to the naked eye when not magnified.  I always zoom x 8 (Ctrl + zoom) at the end of a project - disable snap to - and look very closely at the ends to join up, which will be more apparent when zoomed-in.  Also, a stray line may appear when one clones something and then forgets to move it.
Good luck with the edits :InkSketchEffect: .
0
Share this post
Link to post
Very sweet of you for the kind words....But, temporarily, Mr. Snowman and his accessories are in the Snowman Hospital *sad face*
YOU ARE AWESOME...you may have helped me with the issue I posted on another thread just now, but at the actual plugin thread...on another note, my ShapeMaker plugin only has Zoom x 2 ability : (
0
Share this post
Link to post
		<PathGeometry>
Thank you for letting me know about how to change the name of an .xaml file WITHIN the file. I was able to figure that out easily, within seconds after opening Kaxaml to do so with. I thought the file name could only be changed on the "outside of the file", per se. Again, thank you, Master Yoda
0
Share this post
Link to post
Thank you for those nice words too.
Please see the other thread for what you may not be doing in order to get the larger magnifications ;) .
0
Share this post
Link to post
Zoom button toggles view size to 2x
Shift + Zoom button toggles zoom amount from 2x (default) to 4x
Ctrl + Zoom button toggles zoom amount from 2x (default) to 8x
0
Share this post
Link to post
Thank you Pixey and EER, between the two of you, I have figured out some important things to keep in mind when using ShapeMaker.
Also, Zooming in x8 is absolutely needed. X 12 would be even more helpful but, hey, I'm just thankful for x8 zoom.
0
Share this post
Link to post
@racerx...you are so clever with the animations...impressive!   :pizza:   :mtdew:
0
Share this post
Link to post
This will be of use for making Xmas gift labels. Thank you :)
You are so very welcomed. I'm glad others may find a use for it.
0
Share this post
Link to post
Cool.........thanks!
That is so cool what you made. You make some of the most outstanding and beautiful animations. You are so good at that.
0
Share this post
Link to post
Wait a minute, this shape wasn't created with ShapeMaker. It uses a different format that ShapeMaker can't load. How did you make this shape?
0
Share this post
Link to post
LOL....seriously? I used ShapeMaker. I, like you, figured it out mostly by just tinkering with it. The manual was beyond too technical for me. The video helped me some, too. So, whatever I'm doing, I'm doing it in ShapeMaker.
0
Share this post
Link to post
Before many of us get busy dealing with the coming holiday, I wanted to leave you with my dragon I made.
This shape file is 11.5kb.
LahzaraDragon.zip
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
